large utc clock
large utc clock
Hello when i click utilities /utc clock ,the clocks go full screen massive and i cant reduce them in size only close them or customizes them ,is there a way to make them smaller ,just to add just had a windows update ? many thanks i now you guys are busy
Re: large utc clock
Al,g7rhf wrote: 12 Jan 2023, 01:53 Hello when i click utilities /utc clock ,the clocks go full screen massive and i cant reduce them in size only close them or customizes them ,is there a way to make them smaller ,just to add just had a windows update ? many thanks i now you guys are busy![]()
You are "double-clicking" on the top bar of the digital clock window. That causes it to go to full screen display.
If it is at that full screen display "double-click" on the top bar of the clock window. It will then reset to some smaller value.
You can resize the clock window the same as any "Microsoft Windows". Just hover your cursor over the side/bottom to pull left/right ... up/down. If grab the corner you will get the diagonal arrow where you can also resize the clock window.
Be careful when grabbing the top bar of the window to drag and position where you want it. ONE CLICK to grab/hold to move. Two quick clicks (double-click) will fully expand the clock again.
Re: large utc clock
did as you said and alL good ,interestingly it would not do this yesterday but any hows TNX
