How to delete some defined labels
HB9FAP
Post by HB9FAP »
Hello guys
I have defined a few own labels. Now I want to delete some of them and keep only a few. I first created them and saved under: Utilities, Label definition, after having set margins and so on I saved them and found in the window menu "Load label". How to delete the ones I dont want anymore from that window?
Thanks in advance for any help
Fabio HB9FAP
Re: How to delete some defined labels
HB9FAP wrote: 13 Jan 2023, 22:53 Hello guys
Fabio HB9FAP
Fabio,
Using your File Manager your can go to the folder where those labels are stored and delete as you need.
Here is the path: C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2\labels
HB9FAP
Post by HB9FAP »
Nolan,
Thanks, issue solved with your help.
Fabio HB9FAP
