Anyone else have issues with cluster commands sent directly to the cluster server from the cluster window not working? I am not filtering "inside" the application. Trying to lessen the load.
SET/DXBM 1051393364/16042
no effect. Most bands are still pouring in.
Cluster: VE7CC-1
Tor - K4TOR
Cluster command issues
73 de Tor - K4TOR
Pee Dee of SC
Pee Dee of SC
Re: Cluster command issues
1. Are you registered with the cluster
2. Did it work before
3. Is VE7CC the primary cluster in log4om
4. Are you sure the command is valid - Watch the real-time log window and see what response you get from VE7CC
1. I am registered.G4POP wrote: 28 Feb 2023, 16:47 1. Are you registered with the cluster
2. Never worked
3. It is primary
4.
1749 ve7cc.net:23: -> SET/DXBM 1051393364/16042
1749 ve7cc.net:23: K4TOR de VE7CC-1 28-Feb-2023 1749Z CCC >
1749 ve7cc.net:23: BandMode Filter set to 1051393364/16042
1749 ve7cc.net:23: DX BandMode Filter set to Reject: 30-CW,17-CW,12-CW,6-CW,2-CW,1-CW,70-CW,30-RTTY,17-RTTY,12-RTTY,6-SSB,2-SSB,1-FM,70-FM,60-SSB,17-SSB,12-SSB,6-FM,2-FM,1-SSB,70-SSB,MW-MW
73 de Tor - K4TOR
Pee Dee of SC
Pee Dee of SC
Surely that indicates the command is sent and actioned by VE7CC? What makes you think otherwise?
Sure. But when I look at the Cluster (F8) screen, they still show up. Maybe I'm missing something, Terry. I would think that when I send the command to the cluster from the cluster command line, it would take effect on the cluster screen.G4POP wrote: 28 Feb 2023, 19:14 Surely that indicates the command is sent and actioned by VE7CC? What makes you think otherwise?
73 de Tor - K4TOR
Pee Dee of SC
Pee Dee of SC
Yes but you must allow time for the backlog to clear before you see th filtered results
You know what, Terry, you're absolutely right.G4POP wrote: 28 Feb 2023, 21:22 Yes but you must allow time for the backlog to clear before you see th filtered results
tor
73 de Tor - K4TOR
Pee Dee of SC
Pee Dee of SC
