BETA 2.26.0.7
ZL3GAV
BETA 2.26.0.7
Post by ZL3GAV »
With the new beta downloaded earlier today, the automatic uploads to external services such as QRZ, eQSL, Clublog, HRDLog, & HamQTH stopped working and had to manually updated. Reverting to release version fixed the issue. (I had been using the prior beta without issue, but did not have a copy of this so using release version.)
Gavin
ZL3GAV
Re: BETA 2.26.0.7
Please please read the release notes and you will see why!
ZL3GAV
Re: BETA 2.26.0.7
Post by ZL3GAV »
Thanks Terry.
Are the release notes available elsewhere, other than via within the installer program?
Gavin
Re: BETA 2.26.0.7
ZL3GAV wrote: 09 Mar 2023, 23:48 Thanks Terry.
Gavin
Help/About/Release notes
But as you probably removed it here is a copy
Release note – Version 2.27.0.0
• [NEW] Added active monitoring of main UI performances to identify bottlenecks and external resources poor performances (new PERFORMANCE tag is visible on QSO message area – Log level DEBUG or higher).
• [NEW] Added support for “contest statistics” in cluster view settings. Now the user can show highlights on cluster based on actual contest activity, if enabled, as option
• [NEW] UDP inbound/proxy connections. Added support for user parameters INBOUND CONNECTIONS of those type: ADIF INBOUND, JT MESSAGES, N1MM and QARTEST.
For every single service you can now:
1) decide if you want to update data using external sources
2) decide if you want to update GRIDSQUARE
3) decide if you want to UPLOAD QSO to external sources
4) decide if you want to update CQ values
For JT messages only:
5) Decide if you want to save QSO coming via JT message (alternative to JTAlert, gridtracker and other ADIF integrations) (Message 12 parameter has been removed from the separate option page in settings).
PLEASE NOTE: To add/remove a parameter from a connection you should REMOVE the connection and create it again, as a complete reboot of the connection layer is required.
PLEAS NOTE II: Current connection flags can be shown in a tooltip when hovering over the saved connection row.
• [NEW] ADIF monitor has now an option to decide if you want to update incoming data using log4om info and external sources or import them as they come in.
• [NEW] Statistics band map now show the “preferred confirmation mode view” set in program preferences and no more the fixed “worked” status for each band/mode. Current selection is visible pointing mouse over DXCC number
• [NEW] User awards are now saved on each award update into a backup file inside application configuration folder /awards (other than periodically and on user request from award manager top menu)
• [NEW] Added a “restore user awards” option to automatically restore user awards after a new version update (award manager top menu). This action cannot be performed automatically on application updates yet.
• [NEW] Added LOTW ONLY filter in cluster view. Small changes in cluster filter tab page
• [NEW] Clicking on callsign image in callsign lookup area will open a new screen with full size image.
• Awards placed in the IGNORE LIST (in settings) will not be shown in award statistics page
• A specific yellow warning is now raised if external source data check took more than 2 seconds
• Focus no more returns on main CALLSIGN field when lookup is complete
• User award backup is now zipped
• Added more info on message area when exceptions and data are recovered from internal archives (grid and state)
• No more updates on JT grids when not explicitly required by the user (with the specific adif or JT option)
• Main UI data entry area highlight set on all fields. Some hidden tabs have been removed for a more pleasant experience while tabbing between fields.
• [FIX] Fixed tab order for CONTEST mode (CALLSIGN -> RECEIVED -> SENT -> RST SENT -> RST RECEIVED)
• [FIX] Fixed an issue with lowercase <eor> on ADIF import
• [FIX] Fixed QSL VIA label not hidden in QSL manager when confirmation mode was different from QSL
• [FIX] Fixed main UI notification background color box
• [FIX] Gridsquare is no more updated when a QSO is received through UDP (an option for that will be added at a later time) or JT message 12
• [FIX] Focus loss on date/time data entry when changing QSO date in a locked date box after 3 seconds issue has been fixed. Now the country/exceptions/awards are checked when date is changed and field is leaved (or when you save with enter key)
ZL3GAV
Re: BETA 2.26.0.7
Post by ZL3GAV »
Thanks Terry.
I reinstalled on my non production computer, and extracted the help notes.
My fault here; I should have read the notes more carefully, that I would need to make amendements to the existing settings requiring to be modified to ensure normal functionality for uploads etc.
I will look forward to setting up later.
Gavin
ZL3GAV
ZL3GAV
Re: BETA 2.26.0.7
Post by ZL3GAV »
Hi Terry
I reconfigured the UDP connections for JTAlert etc, so the automatic uploading to QRZ etc are now working correctly.
With the warning triangle for a slow connection in the final release version can this have an option to turn off please?
Internet is 1GB speed up/down here but latency etc to northern hemisphere external databases, say QRZ may have bottlenecks. Still perfectly usable.
Thanks.
Gavin
ZL3GAV
Re: BETA 2.26.0.7
There is no provission for turning the alert off at this time
