I've manually had to update satmodelist.txt for the last couple version to add a missing mode.
Could you add "UU" to the list please? This is to enable GreenCube IO-117 logging, as it uses UHF up and down.
satmodelist - missing mode
Rick, VK6RK
OF77xw
OF77xw
Re: satmodelist - missing mode
Rick,VK6RK wrote: 21 Mar 2023, 00:26 I've manually had to update satmodelist.txt for the last couple version to add a missing mode.
Did you modify the file via the Resource Editor? If you did it will save the modified file with an edited file extension of _user.txt
That way it will be there after the Log4OM updates.
Thanks Nolan, didn't even know about that function. Always edited it manually. Done it there now.KI5IO wrote: 21 Mar 2023, 01:25 Rick,
Cheers, Rick
Rick, VK6RK
OF77xw
OF77xw
