Cluster needed award colors coding not working (for me)
9k2hn
Post by 9k2hn »
I'm having an issue with the needed countries color not appearing as it should, in this example, YI1BGD is needed on 10m as a new country but no color code appeared.
I'm attaching both screen shots
Re: Cluster needed award colors coding not working (for me)
LOG4OM Version number ????????????????????
9k2hn
Post by 9k2hn »
V2.27.1.2
You don't have country field displayed in grid, its that field that will be highlighted
9k2hn
Post by 9k2hn »
Still no color
Check filter tab in box to right
9k2hn
Post by 9k2hn »
Here is the filter setting
Screenshot 2023-04-21 211454.png (17.15 KiB) Viewed 3329 times
9k2hn
Post by 9k2hn »
any news about this bug? anyone could see this problem?
Not a bug because it works fine except for you as you can see from my screen shot below the band/mode not worked is highlighted yellow and is displaying as such in cluster.
Suggest you try unchecking the 'Keep band on mode' box and display the correct columns for band and emission type, not just frequency.
None of your screen shots display those columns and they are where the highlight will be seen - Not the frequency column, check user guide for information
9k2hn
Post by 9k2hn »
I have done what you told me and now it is working as expected.
Thank you
