trying to understand filters
G5ART
Post by G5ART »
Label Print01.png (99.79 KiB) Viewed 912 times
Im trying to write a filter that will pull out all the Buro, Via Bureau, direct types from the QSL via record. but as you can see in the image this record has a lot of multi word entries.
Can someone explain if this is actually possible to do
many thanks
Russel
Fat Finger Typing can often cause things to break!! :? :shock:
KA4CDN
Re: trying to understand filters
Post by KA4CDN »
Russel,
I think you want to use the QslVia field and the LIKE match along with an OR statement. Something like this should get what you want if I understand what you are after:
Screenshot 2023-06-02 133459.png (20.41 KiB) Viewed 830 times
Mike
