Send Confirmation qrz.com with N1MM
iu8moa
Post by iu8moa »
Version 2.27.1.0
The qso's imported via UDP from jtdx after about a minute are automatically sent to qrz.com, eqsl, clublog after having made the modification with the new version. The problem is that the QSOs imported via UDP from N1MM are not sent automatically to the various entities previously described.
The qso is imported regularly and updated with the various entries and logged perfectly, like in JTDX but they are not sent. Did I forget something??
Re: Send Confirmation qrz.com with N1MM
Enzo,
Did you enable the Upload QSO option when setting up the N1MM UDP Inbound Connection?
iu8moa
Post by iu8moa »
Thank you Nolan.......................................................it was not set :oops: :oops: :oops: :oops: :oops:
