Hi all,
Just hapenned recently now QSO's are logged automatically by JTDX the information from qrz.com are not populated, I need to manually edit QSO and update data.
Is this hapenning to someone else ?
v2.27.1.2 // No qrz.com data for FT8/FT4 QSO
73 de F4BPO Greg
Re: v2.27.1.2 // No qrz.com data for FT8/FT4 QSO
I found out also that none of external services updates works (not updating Clublog or QRZ.com anymore as well)
73 de F4BPO Greg
Greg,F4BPO wrote: 13 May 2023, 16:08 I found out also that none of external services updates works (not updating Clublog or QRZ.com anymore as well)
Have you updated to the latest version (Beta V 2.27.1.2 March 24, 2023) that you can download
here: https://www.log4om.com/download/
Have you read the Release Notes?
Have you then followed those Release Notes and "deleted" your former UDP Inbound Connections?
Have you then re-established the UDP Inbound Connections making sure your 3rd Party APPs and the ports properly match?
Have you made the appropriate choices to have those FTxx inbound QSOs uploaded to the various External Sources?
Look at this information as well: viewtopic.php?t=8260
The most current User Guide (23/03/2023 9:15 PM) also has extensive information starting on Page 216.
Yes i mentioned in the subject the version I use.
I followed the information but let me try again.
I will revert
I will revert
73 de F4BPO Greg
Ok I probably did something wrong, it works now !
73 de F4BPO Greg
