Version 2.27.1.0 WARNING
USERS OF FT8/4 JT SOFTWARE MUST DELETE EXISTING UDP CONNECTIONS AND RE ESTABLISH THEM
Because each of the FT8/4 programes like WSJT, JTDX, JTAlert etc have differing ideas on what and how data should be transfered to other software we have just spent a solid two weeks re-writing the UDP system on Log4OM
Users now are able to select which particular JT software they want to connect to and decide on what update as below.
1) decide if you want to update data using external sources (USE_EXTERNAL_DATA)
2) decide if you want to update GRIDSQUARE (UPDATE_GRIDSQUARE)
3) decide if you want to UPLOAD QSO to external sources (UPLOAD_QSO)
4) decide if you want to update CQ values (UPDATE_CQ_ITUZONE)
5) decide if you want to save a QSO through JT message (ex message12 option)
All of this is covered in the release notes and user guide which accomanies version 2.27.1.0 SO PLEASE READ THEM before posting here for help!
These EXTRA enhancements also apply to the ADIF Monitor facility.
