Can't Upload to LOTW fromLog40M
AH6TX
Post by AH6TX »
When i go to QSL manager and select I place the SENT: TO REQUESTED and the RECEIVED to: Blank. I then press the search button, which brings up the records, which in this case was 43. I then press SELECT REQUIRED.
Next I press the UPLOAD BUTTON. this takes me to the next page where I then press the UPLOAD BUTTON.
The first time I perform this project the LOTW response said it was uploading but never did anything. I then closed the page and tried again.. since that time the only response i get is LOTW End.
I don't know what to do now.
Please advise.
Howard
AH6TX
ng7v
Re: Can't Upload to LOTW fromLog40M
Post by ng7v »
It appears as though your upload was successful on the first attempt. When uploading to LOTW, you will not get a response that is sort of positive but generally cryptic. What you can do is go to LOTW's web site, log in and look at your recent QSOs (one of the top menu items followed by a small link that says list recent QSOs. You should see them there.
Ron (NG7V)
