2.28 error on map
pe1eec
2.28 error on map
Post by pe1eec »
Used to work fine just before the upgrade, Now I get this an error
"exception the operation has timed out. We don't have imagery at this zoom level in this region."
Re: 2.28 error on map
The callsign of the station to check ? I have worked some stations 2day and the map was fine.
pe1eec
Post by pe1eec »
DF5WW wrote: 08 Jun 2023, 12:02 The callsign of the station to check ? I have worked some stations 2day and the map was fine.
It's ok now. Thinking it might be something with a new installation as one of my mates had exactly the same after installation.
pe1eec wrote: 12 Jun 2023, 09:48
Martin,
What callsign in particular did y'all experience this with. That is what Juergen was asking.
If you could provide that or a few callsigns if experienced with more than one we can test and attempt to replicate.
Also which of the 3 Map Providers have you selected to use? Google Maps, Bing Maps or Open Street Maps
That setting is at: Settings / Configuration / Program Settings
EC6DX
Post by EC6DX »
I did not find "Grey Lane" on left Map...
Best 73
Jose EC6DX
EC6DX Balearic Islands
EC6DX wrote: 14 Jun 2023, 15:56 Hi,
Best 73
Jose EC6DX
Jose,
Tnx for head's up. If you open the View / World Clock the 'gray line' does show up.
I'll give Lele a head's up to see about a fix for the lack of gray line in the Main (F6) panel.
EC6DX
Post by EC6DX »
I installed new version today 2.29.0.0 and still not repared... it is a shame, because it was working in last versions...
If anybody know something about that, I will apreciate his help
Best 73
Jose EC6DX
EC6DX wrote: 12 Sep 2023, 17:23 Hi,
Best 73
Jose EC6DX
Jose,
If you wait a moment or two or three the gray does show up. Not sure for the reason why the delay, but I'll ask Lele.
Update: Terry & I have done some testing and have experienced below ...
I have Log4OM on two "more mature" (IE: older) laptops and the gray line takes between 8 to 10 seconds before it appears and I also have a fiber optic internet connection.
Terry response for the gray line to appear is ~3 seconds.
Couple items of note: Terry's computer is far new/faster than my two older laptops and I'm also going to have Frontier check out and hopefully optimize my fiber network connection.
So, I don't think what you are experiencing is out of normal that is based on many factors as the tests that Terry and I have done have shown.
EC6DX
Post by EC6DX »
Hi
Yes, there is a small delay, but the color is very weak and it can hardly be seen with the map that I have configured (alternate 2) it can hardly be seen. I have tried the main map and it does look good, but I like the second map better since you can see the relief of the planet.
In 2 versions before, it was perfect...
Best 73
Jose EC6DX
Jose,
Got it ... I'm replicating that as well. I've just overlooked the very (VERY) faint gray line. :oops:
I've asked Terry & Lele to look into.
