Incorrect 'Nearest METAR station' and METAR not loading.
G0DDF
Post by G0DDF »
Firstly, I would like to say what a great bit of software LOG4OM2 is. I used to run Ham Radio Deluxe, but have changed to LOG4OM2. Many of our fellow radio amateurs locally are also running it.
I am running LOG4OM2 version 2 v.2.28.0.0 (latest version), but this was also happening with previous versions. I have been running LOG4OM2 for a few years.
I have, I believe, correctly configured LOG4OM2 I followed Terry's very useful YouTube videos (thank you Terry!).
Details of the issue:
I have correctly configured my 'Station Information' - please see screenshot attachment.
Station Information Screenshot 2023-06-10 114850.png (166.25 KiB) Viewed 2333 times
The 'Program Notifications' show that the 'METAR INFORMATION UPDATED FOR UK MET EXETER' - please see screenshot attachment.
Program Notifications Screenshot 2023-06-10 114754.png (12.85 KiB) Viewed 2333 times
The 'Weather data' shows 'not available/loaded'- please see screenshot attachment.
Configuration Screenshot 2023-06-10 114625.png (60.76 KiB) Viewed 2333 times
The METAR Station of EGRR is incorrectly set against my Station Information. I see how this has happened. I believe that it is a mix-up of when the Met Office moved from Bracknell to Exeter, EGRR, although listed as 'UK MET EXETER' still reports the weather for Bracknell. See information below.
I cannot find a way to change the METAR station to EGTE Exeter Airport. I find 'Nearest Airport' and 'save and exit', but it still sets it to EGRR, so I am guessing that this is done internally from a look-up table.
UK MET EXETER EGRR 03763 50 44N 003 29W 27 X 7 GB
Bracknell / Beaufort Park, United Kingdom (EGRR) 51-23N 000-47W 0M
Nov 07, 2015 - 07:50 AM EST / 2015.11.07 1250 UTC
Wind: from the WSW (250 degrees) at 10 MPH (9 KT):0
Visibility: greater than 7 mile(s):0
Sky conditions: mostly clear
Weather: Cumulonimbus clouds observed
Temperature: 75 F (24 C)
Dew Point: 57 F (14 C)
Relative Humidity: 53%
Pressure (altimeter): 30.03 in. Hg (1017 hPa)
ob: EGRR 071250Z 25009KT 9999 FEW060CB 24/14 Q1017 NOSIG
cycle: 13
EXETER AIRPORT EGTE 03839 50 43N 003 25W 30 X T 6 GB
Exeter Airport, United Kingdom (EGTE) 50-44N 003-25W
Jun 10, 2023 - 06:20 AM EDT / 2023.06.10 1020 UTC
Wind: Variable at 3 MPH (3 KT):0
Temperature: 66 F (19 C)
Dew Point: 59 F (15 C)
Relative Humidity: 77%
Pressure (altimeter): 29.91 in. Hg (1013 hPa)
ob: EGTE 101020Z VRB03KT CAVOK 19/15 Q1013
cycle: 10
Any help would be appreciated. I expect that his must also be happening to others in this area.
Thank you in advance.
Kind Regards
Dave G0DDF
Re: Incorrect 'Nearest METAR station' and METAR not loading.
Yes I see what you refer to I think we have a small program glitch and will check with Lele
G0DDF
Post by G0DDF »
Thank you
Checking and fixing if there is something wrong, next beta
G0DDF
Post by G0DDF »
Thank you.
General Beta release which resolves issue will be on the website later today
