hamlib lose configuration
f1ssf
Post by f1ssf »
Good morning
While waiting for a solution to make Log40 network work, I am using hamlib, everything is ok, except that Log40 loses the hamlib configuration when I quit it. I have to reconfigure each time, any idea?
73 franck THANKS
lose config.png (77.91 KiB) Viewed 717 times
Re: hamlib lose configuration
If you fill in the settings have you saved it with the Diskette symbol at the upper left ? I always do both (for my safety) i cklick on
"Save and Apply" first and "Save Settings" in the secons step.
Log4OM version nuber?
f1ssf
Post by f1ssf »
Hi Juergen and Terry,
I have the last version: 2.28.0.
But I think I have found. To keep config, I have seen you need to do a special shortcut in SETTING, to recall your personal parameters.
I have tested rapidly, it should be ok.
73 Franck
f1ssf
Post by f1ssf »
hello
I spoke too quickly, after having generated the shortcut for my config, the hamlib parameters are still lost and connexion to 9700.
Am I doing something wrong or is there a bug?
Capture d’écran 2023-07-02 160051.png (51.87 KiB) Viewed 682 times
