FTP problem from Log4OM
F6FLU
Post by F6FLU »
Good morning
I have problems with my website management (Web integration)
I generate a web page with as "source File" Log4om.html
and the generated file is saved on a disk
Then I validated "enable FTP" to transfer this file to my site
I would like to point out that it has worked for years without any problems.
I also specify that I had rights problems on my discs that I tried to repair these rights
And since I have problems
If I look at the Log4OM debug it says that I don't have the rights to access the generated file (My_Log.html)
I tried to generate this file on 3 different disks and at the root of these disks and I always have the same problem
2023-07-12 10_26_44.jpg (24.09 KiB) Viewed 1428 times
BUT :
in fact the file is indeed generated on my disks without problem so it is not access to the disk folder that is the problem but it is Log4OM's access to this file during FTP that is the problem (well I think)
That is to say that the FTP from Log4OM does not work anymore because Log4OM does not have access to this file whatever the place where I put this file
Log4OM is launched in administrator mode
I think you have to change the rights somewhere so that Log4OM can access this file regardless of where this file is located
But I don't know where I need to check these rights
If someone could guide me
thanks in advance
Dan - F6FLU
https://F6FLU.org
Re: FTP problem from Log4OM
Have you tried running Log4OM as an administrator
F6FLU
Post by F6FLU »
Yes as I said in my message
"Log4OM is launched in administrator mode" :-)
Dan - F6FLU
https://F6FLU.org
Sorry missed that
Probably caused by a windows update changing permissions
F6FLU
Post by F6FLU »
it's quite strange
by monitoring the ftp with Filezilla I find that the first time it works, ie if I quit Log4OM then I restart and wait for the transfer; the first transfer works well I recover my file well on my site (https://f6flu.com/derniers-qsos/)
If I wait for the next transfer occurrence
the file has zero size on my site, it was overwritten by a blank file because there was an error during the transfer
If I look at the "LogViewer" we can see this problem very well.
When launching Log4OM the transfer is done very well
I don't touch anything, I'm just waiting for the next transfer made by Log4OM and well on the second transfer I have an error and if I leave it like that each time there is an error as if Log4om had changed the rights of the original file
see screenshot of the Log
2023-07-12 13_56_19.jpg (163.66 KiB) Viewed 1420 times
Dan - F6FLU
https://F6FLU.org
I will ask lele to check but suspect its caused by windows
Is the file correctly created on windows folder? Can you open it normally?
F6FLU
Post by F6FLU »
Yes no problem to open and edit this file
Dan - F6FLU
https://F6FLU.org
Let's see if it's something related to log4om installation...
Can you try unpacking a log4om "portable edition" and run it from a different folder?
Is Log4OM "blocked" by firewall in some way? is there an exception on FTP port for Log4OM or an explicit block?
F6FLU
Post by F6FLU »
The peculiarity that I see
If I delete the file generated by Log4OM and quit L4OM then I restart L4OM; L4OM therefore creates this file since it does not exist and there the transfer goes well
On the other hand, on the next "turn" I do get the error
I agree with Terry I think it's a rights problem in windows.
Is there a modification of the rights of this file after the creation of the file? I don't know
if you want to take control of my PC to see if you find anything, it's no problem for me
Thank you again for trying to help me in solving this Pb
FYI I only detected this problem (which is not a problem in fact I can do without this FTP transfer) but it's just to understand because before it worked without any problem
Dan - F6FLU
https://F6FLU.org
