Cluster updates
NN1D
Cluster updates
Post by NN1D »
how can one get a cluster address changed from
k1rfi.com
to
k1rfi.net
is there a master file kept somewhere to be updated with changes
Thank you
73 -
NN1D
Re: Cluster updates
NN1D wrote: 26 Aug 2023, 12:46 Hello,
k1rfi.com
to
k1rfi.net
Thank you
73 -
NN1D
Antone,
At: Connect / Telnet Cluster / Cluster Management / Connections
You can edit the Host as you need.
Once done editing tap the diskette icon and the "edited" cluster will be saved and will have a "U" tag added to the cluster name.
Even with periodic cluster updates to Log4OM your "user edited" cluster will remain unchanged until you decide to make changes to it.
NN1D
Re: Cluster updates
Post by NN1D »
Thank you!
I own K1RFI.net /.com and i wanted to update the master list so everyone has the proper DNS name and port, not just me.
it's changing from k1rfi.com to k1rfi.net, both DNS's will be available but k1rfi.net will be the end result.
73 -
Tony
NN1D
Re: Cluster updates
NN1D wrote: 26 Aug 2023, 13:16 Thank you!
73 -
Tony
NN1D
Tony,
OK ... understand. Lele and Terry know who maintains the master cluster list and will advise how to advise that person to address same.
Re: Cluster updates
Topic has been moved to the Log4OM V2 User Support.
No development is going on with respect to V1 of Log4OM.
Re: Cluster updates
Version one is no longer supported and the cluster server list is an automatic update from an external source so its the list keeper that will change the cluster address
