I have noticed that there are times when LOG4OM will freeze when there is an issue with the Cluster that I am using. I normally use W3LPL as my cluster. I do not send the spots from LOG4OM to my SmartSDR Screen. So I know that is not the problem. But I guess if the cluster for some reason shuts down the Program seems to freeze. If I X out the Cluster Screen it seems that things go back to normal. I then restart the cluster and it will send spots to the LOG4OM Bandmap. Is there a reason why this is happening? When I use N1MM and the cluster goes down, the whole program does not freeze. But for some reason it occurs with LOG4OM.
Mark Griffin, KB3Z
LOG4OM Freezes due to Cluster Issues
Re: LOG4OM Freezes due to Cluster Issues
What Log4OM version are you using - Help/about info - Please dont say the latest version!
What Windows version are you using?
Have you tried a different cluster server?
Are you using a detached cluster window or what exact window are you refering to?
