Hi all
I help REF sort incoming QSL cards, so I know how important it is to have a readable label.
3 comments :
1/ is it possible to have the QSL manager appear in big letters, as this is an important info for QSL sorters ?
2/ Is it possible to have 1 overall comment line, instead of 1 line per QSO ?
3/ Is it possible to get rid of the country name and number, as nobody uses that ?
Thank you and best 73
Paul F6EXV
QSL LABELS
Re: QSL LABELS
I apologise for the slow response but I have been in hospital and slowly catching up.
All sensible suggestions and I will move this thread to Feature suggestions where it will be used as we continue development.
Thank you for your input and once again please accept my apologies
Re: QSL LABELS
You do not need to apologize ! Wish you full and speedy recovery !
Paul F6EXV
Paul F6EXV
Thanks + 73
Paul F6EXV
Paul F6EXV
Re: QSL LABELS
I will check if i've enough space, but it shouldn't be a problemF6EXV wrote: 27 Oct 2023, 08:20 Hi all
3 comments :
Yes, if you have one QSO per label. But what if you have multiple QSO with different labels?2/ Is it possible to have 1 overall comment line, instead of 1 line per QSO ?
Those info are used by QSL sorters when a QSL manager is not set... and in any case, it's used by QSL sorters to easily identify destinations3/ Is it possible to get rid of the country name and number, as nobody uses that ?
Paul F6EXV
Re: QSL LABELS
Hello Daniele
1/ That would be great
2/ Good point.. If there are more than 1 labels, the comment will be repeated on each label I imagine. Ideally, one time would be enough on the last label, but not sure if this would be easily programmable...
3/ I may be wrong, but QSL sorters know which country is related to a callsign. Or maybe the country name would be enough ?
Not sure how it works in other countries, but here in France, the sender is supposed to sort cards per country of destination, and clearly mark them.
Thanks + 73
Paul
Thanks + 73
Paul
Thanks + 73
Paul F6EXV
Paul F6EXV
Re: QSL LABELS
By the way, I am a QSL sorter for REF, so I know what I am talking about...
Thanks + 73
Paul F6EXV
Paul F6EXV
