Wesley Jones <sindbadwes@gmail.com>
8:39 PM (1 minute ago)
My issue is : Trying to get Log4OM2 to work through my RS-BA1 Remote software to my IC7300 at another location and both change 1) the frequency on the rig and 2) “populate” the CALLSIGN/operator name/frequency panel on Log4OM when I click on a spot in the Log4OM cluster panel.I'm routinely using RS-BA1 from a distant location to run my 7300 at the shack/antenna location.I'm also using Log4OM as my logger/cluster at my distant location and want it to work through the RS-BA1 to drive my rig's freq/band when I click on a cluster spot. I have Omnirig installed at the distant location computer.
Can anyone tell me how to get this to work, and if you did, how did you set it up? I have Enterlogic VSPE available.
Wes AI4FH
RS-BA1 and Log4OM
Re: RS-BA1 and Log4OM
I dont think you can change the com port in RS-BA1 and as you cant share com ports it wont work.
Try using Win3Icom instead of RS-BA1 its a better program and can use virtual com ports etc
I have found a work-around that allows me to use Log4OM and RS-BA1 remotely to my remote rig. I will be glad to explain it to anyone who is interested. Pls email me - my email address is on QRZ.com. Wes AI4FH.
Terry - where do I find Win3Icom? I'm searching but not finding it.
