In the event of a power failure, the PC log4om will lose all settings when it is restarted. Station config, remote uploads, database etc etc everything is blank. Where does log4om store all this data??. I had to helping someone because he had two power outages with the log4om in operation. Each time when restarting, the welcome screen poptup and the input fields were blank. After loading the database, the station data must still be entered again.I can restore the log without any problems .but with restore options or backups the config fields remain blank Where can I find the saved data in the log4om root??
And how te replace them?
on7bbr
station configuration by powerfall
Re: station configuration by powerfall
It will be in the backup files that he set up - see the user guide re backups and also emergencies
Thanks for quick answer. In case of a future defect I will give it a try.
Rudi
Rudi
