Copying info from Cluster data into QSO form
yt9tp
Post by yt9tp »
Currently double click on cluster record creates new QSO and sets callsign. Usually there are more useful information in cluster like diploma info, special cal info, activation info etc.. Such info is only displayed, we have no option to copy and paste into QSO info. So we have to retype.
Is there a chance to allow copying?
Re: Copying info from Cluster data into QSO form
Already there!
Double click on spot to transfer info to QSO input area
Now click the Comments drop down and there is the information from the spots comments/notes
Screenshot 2014-04-21 17.44.30.png (149.61 KiB) Viewed 3469 times
yt9tp
Post by yt9tp »
Double click copies only call sign is copied. I want to copy information from fields Note and Other info, as there is usually detail about operation, IOTA number, WFF or WCA id or such.
Hi, probably you missed that in Terry screenshot: check the COMMENT field, now has a DROP DOWN with all rows coming from SPOT NOTES where you can select what you need.
