Good morning
for the filters in the "View/Award status" section, "Award filters" tab, you can filter on "band & mode"; country; date etc ... but we cannot filter on a particular call
I would like to be able to filter the result by selecting a particular Call in addition to the current selections
For example :
I select the RDA "award" then I select an "add range" like 01-05-2024 to 28-05-2024
AND
I would like to add as a filter
AND CALL = xxxx
Would this be possible to do?
if yes how to do it exactly?
Can we make this kind of award ourselves? Or if not, is it possible to have this possibility?
THANKS
Search award by Call
Moderator: OE6CLD
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Re: Search award by Call
Probably best to use award manager to create an award, once done you can apply the other filters
Yes Terry but I don't know how to do this kind of modification ...
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Dan,
Email me details of the award and I will see if I can do something
OK Terry, thanks
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Hi Dan,
"Award filters" in Award status does not allow to search for callsigns.
What you could do is change to the "Massive editor" on the same screen. There you will see a list of all stations matching your filter criteria from "Award filters". Now you can click on "Filters" below and also filter for a callsign (or anything else in the log), which will give you much more flexibility.
Hope this helps.
Claus
Hope this helps.
Claus
Claus, OE6CLD/DJ0DX/EI7JZ
