CI-V transceive and band decoder
ik3umt
Post by ik3umt »
I have an Arduino band decoder connected to CI-V connector of my IC-7800 listening to 7800 CI-V output in transceive mode (Log4OM CAT via serial port).
It works no more unless I disabled (commented out) transceive mode [init] paragraph on 7800 ini file.
Issue:
When I change band from Log4OM , IC7800 changes accordly, but arduino decoder doesn't follow.
If I change band from 7800 keypad or vfo knob, arduino decoder works properly following radio.
No issue with same connections using Easylog.
Suggestions please ?
Re: CI-V transceive and band decoder
ik3umt wrote: 10 Jun 2024, 23:02 I have an Arduino band decoder connected to CI-V connector of my IC-7800 listening to 7800 CI-V output in transceive mode (Log4OM CAT via serial port).
Issue:
Ciao Fredrico,
This is one to ask Omnirig or rhe Arduino forum about as I have no knowledge of the device.
ik3umt
Post by ik3umt »
From what i've understood, Log4OM , as well as all other softwares, passes comands like "pmFreq" , "pmFreqA" , "pmFreqB" and so on , to Omnirig , then dialogue between PC and radio via serial interface is an Omnirig thing.
So, I should be able to test behavior with Omnirig client tool...
ik3umt wrote: 11 Jun 2024, 11:57 From what i've understood, Log4OM , as well as all other softwares, passes comands like "pmFreq" , "pmFreqA" , "pmFreqB" and so on , to Omnirig , then dialogue between PC and radio via serial interface is an Omnirig thing.
Yes but you might have to open all programs to 'run as an administrator'
nq4t
Post by nq4t »
ik3umt wrote: 10 Jun 2024, 23:02 It works no more unless I disabled (commented out) transceive mode [init] paragraph on 7800 ini file.
I dug in to this and calling this "disable transceive mode" is wrong.
Code: Select all
[INIT1]
;disable transceive mode
Command=FEFE6AE0.1A050102.00.FD
On the IC-7800; Command 1A - Subcommand 050102 sets the RS-232C function; 00 sets it to CI-V. That doesn't disable trasceive mode and forces the 9-pin 232C D-Sub connector to CI-V mode. It can also output decoded RTTY as ASCII over it.
It has no effect on the remote jack.
I won't say this isn't a funky transcieve configuration issue. But the issue isn't Log4OM and it's not OmniRig. The radios might not transcieve packets they're designed for; but if it's sending it's VFO changes on the bus then it *should* broadcast those.
A hack in the Omnirig config might be to send to radio address 00h; that's sometimes an "all hands" call.
ik3umt
Post by ik3umt »
Further investigation and results:
Easylog uses the "choose VFOx then change its operating frequency" method:
TXFrequencyVFOA=FEFE6AE007D0FDFEFE6AE005%fFD
that concatenates two Omnirig command
[pmVfoA]
Command=FEFE6AE0.07D0.FD
[pmFreq]
Command=FEFE6AE0.05.0000000000.FD
Log4OM uses the single command "change VFOx frequency" method:
[pmFreqA]
Command=FEFE6AE0.25.00.0000000000.FD
I suspect the issue is , being in "transceive mode" , the 25 00 command is recognized by 7800 (that changes frequency) then "transceived" to arduino decoder that doesn't recognize it.
In fact, with a fake
[pmFreqA]
Log4OM changes 7800 frequency and arduino decoder changes accordly.
Anyway there's a note on 7800 ini files:
Removed by N6TV - pmFreq command should not be used if pmFreqA and pmFreqB avail. per VE3NEA
and again:
compound CI-V commands not processed consistently per VE3NEA
The ones I'm looking for.... :cry:
ik3umt
Post by ik3umt »
Question: is Omnirig command issued by Log4OM when needed (i.e. double click on cluster row produces a [pmvfoA] ), hardcoded into program or is it user-configurable ?
Hard coded
nq4t
Post by nq4t »
I will simply say this:
A lot of this stuff is pretty horrible; OmniRig, FLRig, even hamlib are pretty janky for what they're trying to do. I wrote one application that used hamlib, was pretty shocked at how poor it performed, and wound up moving the entire project to Arduino and writing my own CI-V communication library.
If it was me I'd start poking the Omnirig configs, putting the commands you want to send in place of what they do, and see what happens. Change [pmFreqA] to command 05.
When I was doing my Arduino project...I would literally just have the thing blast commands until I figured out when the radio got angry.
ik3umt
Post by ik3umt »
nq4t wrote: 15 Jun 2024, 12:47 I will simply say this:
Yes, I think that the solution for customized features is to poking and fooling up original Omnirig commands.
just an example, with Easylog I modified rig .ini file for the simple "vfo frequency setting" to "set vfo A"-"change its frequency"-"shut SPLIT"- "shut dual-watch"
Unless radio doesn't get angry, it's ok ....
