hello,
I would like to know how I can save the choice I made to export today's QSOs in the non-standard ADIF format.
For my activation I do not need to export in the standard format.
I choose the "export selected fields" format which represents 12 "selected items" then I export the file ADIF for this day.
Tomorrow,and the following 10 days, if I want to export my new QSOs I will have to re-choose the boxes to export.
I would like to know if there is the possibility of saving my choice so as not to repeat my choice every day.
I haven't found a solution, please give me instructions if possible.
I thank you in advance, if there is not this possibility of saving my choice I will redo the manipulation every day.
F1ABL Michel
Save the choice "Export select fields"
Re: Save the choice "Export select fields"
When you select export selected fields, the fields that you selected the last time you used export selected fields is remembered.
Or perhaps your using a very old version of Log4OM?
Thank you for your response
My version is Log4OM V2 2.32.1.0
Unfortunately the choice I make is not saved for the next time I am obliged each time the ADIF select file is exported to make the same choice again for the next time.
I can make you a video to explain what's going on.
thank you for paying attention to my problem.
73 Michel
73 Michel
What part of Log4OM2 are you exporting the ADIF file?
I click Utilities>QSO Manager>
I choose the QSO made yesterday to export,
I click Export to ADIF,
I check Export Selected fields,
I choose 12 items selected instead of the 6 proposed,
I save the file ADIF on my PC, in the format I chose.
Today i made some contacts,
Utilities> QSO manager,
I select this QSO made today,
I click to Export to ADIF,
I check again Export selected fields,
the choice I made the day before was not saved I again have 6 items selected instead of 12 that I had chosen.
I don't understand how I can save the ADIF format with the choice of 12, if this is not possible I will do the manipulation every day.
I must activate TM84JO for the passage of the Olympic flame in my department of Vaucluse from June 16 to 23, 2024 all modes and all HF bands.
I wanted to simplify this manipulation so as not to repeat it all week, to keep the choice of the ADIF format that interests us.
Merci Terry 73 Michel
Michel,F1ABL wrote: 14 Jun 2024, 05:33 I click Utilities>QSO Manager>
I just tested and there is a malfunction I will get it resolved but unfortunately not in time for your activity, appologies for the inconvenience
Thank you Terry I understand very well that this cannot be resolved immediately.
I will do the manipulation manually it is not a big chore.
Thank you again for your patience and congratulations to the entire Log4OM team who work on this wonderful software.
have a good day 73 F1ABL Michel
Fixed in Beta 6 release - added load and save buttons
Thanks Terry good info have a good day 73
Congratulations to the Team
