Unable to DL v2.33
Unable to DL v2.33
Three attempts on 2 different PC's result in a partial download before it fails.
Re: Unable to DL v2.33
Just tried it and download was fine, try turning off your firewall and antivirus while downloading
Are there release notes for 2.33? I couldn't find any on the website.
Chris
VK3IK
Chris
VK3IK
They are on both our Facebook sites but here they are again
Release note – Version 2.33.0
• [NEW] Added new button on main UI top bar to quickly open the “fast input” screen
• [NEW] Added load/save preset on ADIF / CSV export
• [NEW] Added basic cluster reconnection capabilities in case of unexpected disconnections
• [NEW] Sometime windows prevents correct CONFIG.JSON save on disk. Added a feature that tries to recover the last_valid_config.json file if main config.json file is missing. If last valid config is not available the application tries to recover the latest config in the default backup folder.
• [NEW] Added a “reference migration tool” (massive and single) to allow users to massively update their award references (reference type award only). Find it in “utilities/award manager” top bar menu and then inside the “utilities” menu. Works for both MY and COUNTERPART references
• Improved CQ/ITU handling and identification on ADIF import
• Improved award import DXCC override mechanism to better perform (related to AwardOverride.csv configuration file that provide correct DXCC data when missing on import source)
• CTY file is now used also when importing a QSO even if the QSO has a date different than today but in the last 30 days.
• Fixed an issue (unexpected format change) in IOTA data file format that prevented correct update of the IOTA reference file
• [FIX] Fixed non standard callsign management in lookup engine
• [FIX] Fixed serial keyer parameter saving options
I just tried to download 2.33 and had the same issue as WA2SQQ the OP. I then tried to download 2.32 and it worked fine.
Chris
VK3IK
Chris
VK3IK
I don't think there is a file issue with 2.33 download. I commonly have issues downloading from the Log4OM server. I would just try again if it fails in the middle. Maybe try another browser.
I downloaded it fine yesterday and just tested again and fine.
I will occasionally have slow d/l's as well. Sometimes they 'hang' or 'abort' and I just tap the browser's d/l button and resume the d/l and it works FB.
I d/l'd v2.33 yesterday afternoon and it came down very fast with no delays.
I d/l'd again last night (different laptop) and it was quite slow and I had to resume, but got it all FB.
Pretty much is always overall network traffic or maybe servers it resides on being busy as well.
I was able to get the entire file on the 5th attempt
