highlight cluster colors not working
on7du
Post by on7du »
Hi guys,
I'm using the default highlight colors for the cluster, but everything still remains black color on greyish background in the cluster. Any idea what might be wrong here?
I'm happy to show during teams/skype call.
Johan
Re: highlight cluster colors not working
Version number ???
on7du
Post by on7du »
2.32.1.0
Please install V 2.33
on7du
Post by on7du »
ok. quite new to log4om, so first need to do some reading on the upgrade procedure. Now that - almost - everything works, i need to make sure an upgrade won't destroy the settings :-)
... but .. weird that I seem to be the only one having this issue.
Just make a backup and download the latest version
No need to uninstall just intall the latest
Settings should be retained but you will have a backup to fall back on although not many users have needed to do that
on7du
Post by on7du »
indeed .. upgrade was very smooth!
Congrats by the way for such a cool program!
Still no coloring... very weird.
so colors are defined as default in the settings - program config - configuration
and if an entry appears in the cluster, all is grey. if i click on an entry, i do see in the stats window for instance that 12m CW is missing, but then it should be colored in orange..
Rgds
Johan
Grey probably means you already worked the country
How many QSO's in your logbook?
on7du
Post by on7du »
12000.
I worked it, but not in that particular mode. Got all DXCC worked, but I still need some on CW or digimode.
If I click on the entry in the cluster, I do see the stats on all bands, where indeed 1 check box is missing, so it is supposed to highlight it with the orange color, right?
Post the Program config/cluster menu here please
