DXCC?
Moderator: OE6CLD
PA7RA
DXCC?
Post by PA7RA »
I have a question
When I look in LOTW I see that I have worked 38 DXCC on 70cm confirmed and Granted
When I look in LOG4OM I see that I have 45 DXCC Granted.
Now I take a qso that I know for sure is a Sat qso 4O4A that qso was made via IO-117 see photo
When I then look in the award refs tab I see that DXCC-SAT is checked so DXCC_sat is submitted and yet it is listed as 70CM Submitted.
What am I doing wrong???
I don't understand so I hope someone can explain this to me I would like to have the correct score that is in LOTW also in LOG4OM.
Tnx Rien, PA7RA
PA7RA
Re: DXCC?
Post by PA7RA »
Forgot 1 Photo.
Rien, PA7RA
OE6CLD
Re: DXCC?
Post by OE6CLD »
Hi Rien,
You're mixing up two different awards. In general and per default Log4OM shows you the entities worked per band - in your case 70cm. Apparently here you have 45 DXCC entities granted in total. This is independent if you worked them directly or via a satellite - as long as you worked them on the 70 cm band.
If you only want to check you SAT contacts you have to select "SATELLITE" in the drop-own under "Predefined Config". Now you only will see the contacts where DXCC-SAT was selected.
Hope this helps.
Claus
Claus, OE6CLD/DJ0DX/EI7JZ
