Filter Clusters
KB3JDL
Filter Clusters
Post by KB3JDL »
I’m loving the built in cluster filer options. Any chance more could be added? For example the cluster node that is reporting the spot and filtering based on the comments field contents would be super nice. For example I could filter on %pota% to see all spots that contain POTA in the comment.
Filtering on frequency would be nice too as I could filter out what I’m not licensed to work.
Thanks all!
Re: Filter Clusters
I personally have found the best option for me is to do all this at the server level and save various filter configurations with unique SSIDs.
CCuser makes it really easy to set things up the way I want, so I just do that and then enable the filter set in Log4OM by having several connections to the server with different SSIDs.
This works when using Log4om and other programs like contesting software.
KB3JDL
Re: Filter Clusters
Post by KB3JDL »
Thanks Rich, do you have any documentation on what you are doing? I’m trying to understand from what you said but I’m not quiet there. lol
I understand filtering at the server but that seems like a whole additional (fairly slow) step compared to jumping to the cluster tab and typing a filter that filters the table view. I’m probably not tracking what you are describing! Any additional tips would be great!!
Re: Filter Clusters
KB3JDL wrote: 19 Aug 2024, 23:05 Thanks Rich, do you have any documentation on what you are doing? I’m trying to understand from what you said but I’m not quiet there. lol
Not as hard as it sounds
Search Google for dx spider filters that explains what to do
Then send the filter commands you require from the log4om telnet cluster window
