LOTW upload Freezes
NJ0F
Re: LOTW upload Freezes
Post by NJ0F »
I have the exact problem that started a week ago!
NJ0F
NJ0F wrote: 01 Sep 2024, 02:23 I have the exact problem that started a week ago!
NJ0F
Has to be one of the reasons previously discussed in this thread like expired cert or wrong set up, Log4OM does not suddenly stop working unles there is some local or internet issue.
I just tested upload and download and bot worked fine version 2.33, see image below
w7btm
Post by w7btm »
I'm having the exact same issue.
LOTW uploads will lockup if I do more than 10 or 11 at a time. And lockups require me to restart Log4OM. VERY frustrating.
The stop point is always "MANAGED MODE SET" in TSql.
QRZ uploads worked better but it locked up when I tried to to 100. However, those did not require a restart of the program.
The connection to TSql seems fragile for sure. And if it's that sensitive to windows and other updates thats a big issue that needs addressing.
do7mj
Post by do7mj »
Same here LOTW freeze
I try already
-new cert
-with/without password
seems related to the amount if I upload 1 or 5 QSO at a time all is ok
w7btm wrote: 14 Oct 2024, 22:57 I'm having the exact same issue.
w7btm
Post by w7btm »
That's interresting. Hard to say if it's an issue with Log4OM or TSQL....
An Observation on the "LOTW Upload Freezes" situation.
The below is just my 'observation' and 'experience' and may be 'food for thought' (or not). Meaning that it may or may not trigger a thought that might help some OMs find something that will help resolve their situation with this matter.
I used to use Log4OM V1 and when Log4OM V2 was released I started using it and have been using it since that time.
Each/every installation/update of Log4OM V2 has always simply followed the recommended 'path' locations for all the various elements that are part of Log4OM V2. In that I have never selected any external, cloud drive or ever chosen any drive (IE: D, G, whatever) save for the default "C" drive as is the basis in the Windows O/S world.
Same goes for my installation of TQSL. I let the TQSL installer put its related elements in their default locations.
As for setting up LOTW in Log4OM V2 ... I followed what is in the User Guide and the information provided by Terry in his multiple YouTube videos. I went over those videos and the User Guide information several times to ensure that my settings were matching in case I had a typo, etc..
I've also tested the LOTW Upload on Close and it also worked FB for me. I no longer use that feature as I just prefer to physically have a hand in my LOTW uploads so do that via the QSL Manager. A few extra key-clicks and a minute or two of my time for such is not a big deal.
FWIW I've used Log4OM V2 in both the Windows 10 Pro and Windows 11 Pro O/S. All my installations have been on very 'mature' (IE: old) Dell laptops. I finally was able to get a new Dell laptop about one year ago as I just couldn't find parts to keep my 'mature' laptop running. And ... no LOTW Upload Freezes experienced on any of my installations.
I have also uploaded quantity counts of over 200 Q's and most often my uploads range from 50 to 175 several times each week. I have NEVER experienced any 'freeze' of the LOTW uploads in all my years of using Log4OM V2.
I have spent hours reviewing this thread (and others in the Forum) related to the same issue, but have never been able to replicate what has been posted about.
I don't have any magical wand for a possible solution and there 'might be' some glitch in the code, but if that were the case I'm sure that far more OMs would be adding their input about such.
No two installations are alike and each of us have our own ways of setting up our computers and how we load programs on them and often in such variances there might be some very small difference that is the culprit of this issue.
So ... my final thoughts are that it might be wise to take a step back and make notes of your overall installation. Is it done to the default folders/locations? Is TQSL installed to the default folders/locations? I strongly suggest using your local PC's "C" drive for both and go from there and do not install on any remote or cloud drive. Make sure your syntax is proper in the LOTW and TQSL setup and (again) keep the folders/path on your 'local' drive ... NOT a cloud/remote drive.
Finally ... the above are just my observations and 'maybe' those thoughts may be of assistance and then again they may not. However ... give it some thought and review your overall installation and settings very carefully.
Nothing can change as log4om doesn't download patches or other things so if the problem arises in the same version the user has used for some time the problem is not in the Log4OM software its something local
sp2emw
Post by sp2emw »
Answer in the style of "it works for me" ;)
The problem is real, it occurs for many users. For me, sending the log to LOTW does not work when I send more than 10 items.
Win 8.1 32bit, LOG4OM v. 2.33.0.0, tQSL v. 2.7.5
By the way, LOG4OM is the best, thanks for it :)
VK4XAC
Post by VK4XAC »
I have read the posts. This is a frustrating situation for those that seem to have this issue. On my computer, I have not changed or added and apps. The system was stable one day and then the next, TQSL upload stalled on Manage Mode Set. The upload does happen anyway but no indications as before to process. The link with LOTW still seems to be attached and does not end and disconnect. So this process is a real issue, with no one having a handle on it let alone a real solution.
I need help here to solve this and return to normal use.
Anyone??
Cheers Alan VK4XAC
PA1EJO
Post by PA1EJO »
Since LOTW was out for several months in 2024 I have issues with uploading my QSOs to the web database. My conclusion is that it is a volume depending problem, here is my analysis. When I select 5 QSOs then the upload to LOTW runs fine from within LOG4OM, with 10 QSOs it sometimes stalls, and with more than 10 QSOs it usually doesn't work from within LOG4OM. The solution is, select the QSOs that you want to upload in an ADI file, next go to TQSL and do it manually. (This is all Windows 11 and the lastest versions of TSQL and LOG4OM) It is a bit frustrating to see but I think that the LOTW system has a limit to the way you can upload automatically from logbooks like LOG4OM. Either it is a bug in LOG4OM, or it is a limit set by the LOTW management.
