Hey all,
Hope I can get a little clarification here. Not even sure it it's possible. See attached screen capture.
There is a program called Gemini Multi Control which monitors and controls my Gemini DX1200 Amplifier. It has UDP output and it has a place to fill in the IP address (Default is 127.0.0.1) and Port (Default is 9110).
Then it says this as a note under that:
A typical Output Would Be: {
"band":"14MHz",
"antenna":"A",
"power":"410W",
"powerpeak":"413W",
"vswr":1.0,
"current":"19A",
"currentpeak":"20A",
"temp":"35",
"state":"Transmit",
"ptt":"TX",
"trip":"None",
"tempwarning":"0",
"powersetting":"LOW",
"powerdouble":413.0,
"powerpeakdouble":0.0,
"tempdouble":35.0
Is it possible to have it report the TX power for a given QSO to the corresponding column "Recent QSO's" in Log4OM2?
Thanks in advance for any assistance.
W1SPS
UDP output from Gemini Multi Control, TX Power??
- Capture.JPG (42.08 KiB) Viewed 1718 times
Re: UDP output from Gemini Multi Control, TX Power??
Ok, just wondering. Thanks for the reply.
