I have my main cluster display set to display a white background on every line.
When I open additional cluster displays, the alternating white and gray backgrounds appear on the listing. Is there any way to eliminate the alternating backgrounds on additional cluster display lists so that all backgrounds are white?
thanks,
Ed w2xk
alternating gray lines
Re: alternating gray lines
Same way you did with main cluster right click cluster heading and select edit table layout!W2GTR wrote: 18 Oct 2024, 17:36 I have my main cluster display set to display a white background on every line.
thanks,
Ed w2xk
Thanks, I couldn't remember how I did it the first time, memory is fading.
