Problem uploading to LOTW
W2UP
Post by W2UP »
Hi all,
Relatively new user of the software, so bear with me. :D Running v2.33.0.0
I set everything up about a month ago with no problems. Did an intial LOTW up and download which worked fine. Today, I'm attempting my second LOTW up and download. The download worked fine. When I select QSOs for upload, then click the upload button, I immediately get LOTW END in the pop-up window. What am I missing or doing wrong?
Tnx,
Barry W2UP
W2UP
Re: Problem uploading to LOTW
Post by W2UP »
I don't see an option to edit or delete my own post, so will post follow-up. Problem solved!
I found another post on the forum with the same problem. What I had to do was change my temp file from within appdata to elsewhere and problem solved.
W2UP wrote: 24 Oct 2024, 16:59 I don't see an option to edit or delete my own post, so will post follow-up. Problem solved!
Barry,
Glad you got to the 'hiccup'. Tnx for the follow-up.
