Hello everyone,
I have my FT8 logs automatically imported into log4om.
Unfortunately, these QSOs are not uploaded to Clublog.
The QSOs in question are displayed with requested.
The QSOs are not displayed in Clublog.
What am I doing wrong?
best 73s from DL6RDE
Problem with the automatic upload of my FT8 QSOs which are automatically imported
Re: Problem with the automatic upload of my FT8 QSOs which are automatically imported
I am having the exact same problem, except the final posting to QRZ.com.
FT8 posts to Log 4 OM-no problem
Log for OM posts to QRZ.com-no problem
But...when the post originates in FT8, it goes to Log 4 OM, but not onto QRZ.com.
Any way to force or push the posting to go onto QRZ.com?
Thanks,
Russ K6QQX 18 Nov 24
Thanks,
Check upload QSO
Hi Terry, thank you for your reply. I have adjusted the settings and am still not successful.
i'm pretty desperate. can you please take a look at the attachments? thank you so much
best 73s de DL6RDE
best 73s de DL6RDE
- adif.JPG (59.08 KiB) Viewed 919 times
- jt.JPG (129.33 KiB) Viewed 919 times
Have you tried a manual upload of a QSO from Log4OM QSL manager, does that work?
You dont need ADIF monitor if your using UDP which is far better
Good morning Terry,
yes, the manual upload works ...
73s de DL6RDE, Charlie
Then the only thing I can think of is that the incoming QSO from WSJT has the confirmation status set to something different to that set as default in Log4OM
e.g. If WSJT QSO is marked with QRZ sent status = Requested but Log4OM is set to a default of QRZ sent status = No then the incoming QSO's will be regarded as already sent because Log4OM is looking for a sent status as No.
And of course the reverse if WSJT marked as sent = No but Log4OM set to check for sent status = Requested
Check how the incoming failed QSO's a re marked and compare that to the default settings
