When I receive a qsl card and log it as received it does not save it
because when I upload it to clublog it still comes up as worked but
not confirmed. What do I need to do to confirm it on log4om?
confirm
Re: confirm
Qsl info and I if I click sent or received it does not seem to save it when
I save and exit or upload when I come back in again it is blank?
Is that how you save the information or is there another way?
Re: confirm
When you do that there are TWO save buttons - One is a floppy disk to right of the QSL chooser menu and the other is the Green check mark in top tool bar.MI0MIX wrote: 22 Nov 2024, 21:41 Qsl info and I if I click sent or received it does not seem to save it when
You set a confirmation sent or received and then click the floppy, make any more confirmations sent and click floppy each time, finally click the green check mark for final global save and close.
However the QSL manager is a far better way of doing this, I suggest that you read the user guide and watch the three tutorials below
https://youtu.be/7yuxJhVEFFI?si=4Do2yLdLO49037m_
https://youtu.be/xingbq1d-4o?si=BhimQbDO9hpeqN2a
https://youtu.be/7cthCCVwkXg?si=R3l-v2QR938xpXie
Re: confirm
Thanks Terry that worked 100%.
