Display width of text content in configuration menu too small
DL8BDU
Post by DL8BDU »
Hello, I have a new PC with Windows 11, 64bit, processor 12th Gen Intel(R) Core(TM) i7-12700 2.10 GHz, 16GB RAM. On my old PC, Log4OM ran slowly, with frequent system crashes. But all settings and the display in the windows of the configuration menu were OK. In order not to carry over any errors from the old computer, I installed the latest version of Log4OM (version 2.34.0.0) and reconfigured everything, i.e. no data transfer from the old PC, except for the SQL database.
Unfortunately, I cannot complete the configuration because the window size in the configuration menu is too small for some displays, parts of the text or the input window are cut off at the right edge.
I found a solution to the problem in the forum, but it related to importing old configuration data from a backup. Unfortunately, you cant adjust the window size, and it is not due to the font size settings in Windows. can someone help??
73, de Klaus
Log4OM Konf. menü.png (60.27 KiB) Viewed 1720 times
Re: Display width of text content in configuration menu too small
Seems it could be your display resolution, try another
DL8BDU
Post by DL8BDU »
Englisch
As already written, I changed the font size settings several times. this only affects the character size, but not the window width.
73, de Klaus, DL8BDU
I said display RESOLUTION not font
DL8BDU
Post by DL8BDU »
Hello Terry, thank you very much for your feedback. English is not my native language, I apologize for any difficulties in communication. I have now spent 1 hour on my computer with an IT specialist. All attempts to find a solution to the problem have failed. The error is not due to the settings on the PC. Incidentally, my problem also applies to downloading the QSL cards from EQSL. If you display this, some of the information is missing on the right side, so it usually cannot be used. Am I the only user with this problem???
Screenshot 2025-01-06 081028.png (208.9 KiB) Viewed 1410 times
DL8BDU
Post by DL8BDU »
So no one here can help me, the problem remains unsolved.
This phenomenon doesn't just occur with me, but with other OMs as well, at least the reduced width of the E-QSL printouts.
That's bad and unsatisfactory.....
73 de Klaus DL8BDU
