Cluster utility
w9mdb
Re: Cluster utility
Post by w9mdb »
Without QRZ xml you'll get an error message on every decode.
You may as well just wait for a new version where you can turn it off.
va3vf
Re: Cluster utility
Post by va3vf »
Working with host 127.0.0.1 now. No idea what was going on before.
Getting some other error messages but was unable to capture them. Will keep an eye if it shows up again.
va3vf
Re: Cluster utility
Post by va3vf »
w9mdb wrote: 16 Jan 2025, 05:27 Without QRZ xml you'll get an error message on every decode.
OK, will do.
Thank you very much for your prompt replies!
w9mdb
Re: Cluster utility
Post by w9mdb »
I took a look at this and QRZ is very embedded in the program so I'm not going to be able to make it work without the XML lookups.
Sorry....
va3vf
Re: Cluster utility
Post by va3vf »
w9mdb wrote: 16 Jan 2025, 14:25 I took a look at this and QRZ is very embedded in the program so I'm not going to be able to make it work without the XML lookups.
Sorry....
Fully understand. Thank you for looking into it.
Vince
Re: Cluster utility
va3vf wrote: 16 Jan 2025, 18:36
Sorry....
Vince
:D
Z31PM
Re: Cluster utility
Post by Z31PM »
.NET runtime installed and updated, but I receive this error
Windows 11 Pro 24H2
Mishel, Z31PM
w9mdb
Re: Cluster utility
Post by w9mdb »
Should have installed .Net 9
Z31PM
Re: Cluster utility
Post by Z31PM »
I did. V. 9.0.1 x64
Mishel, Z31PM
w9mdb
Re: Cluster utility
Post by w9mdb »
I've had problems before installing .Net which took several reboots and installs before it finally worked.
