Good evening all,
My first post, so go easy on me!!
I read the GB2RS News broadcast on a Sunday morning on 7.127 LSB.
Currently, there are 3 news readers around the UK that broadcast on the 40 Mtre band, and we use Google sheets (shared by all 3 readers) to create a live list of people that are calling in for the pre news net.
This allows us to see, at any time (as it is Realtime) who has called in.
We have 3 fields in Google sheets:
Callsign, Name and QTH.
Currently, this is being entered manually in each field, so can take some time to complete.
I use LOG4OM as my logging program, - is there any way that if I type a callsign into LOG4OM it will automatically be populated into google sheets just by logging it into LOG4OM? - this way I have a log pf the QSO, but in the same instance, the data I wish to select can be displayed live on google sheets so that the other news readers can see it?
Any assistance is much appreciated.
Very Best regards,
Troy G7LHK / GB2RS
Web integration to Google sheets
Re: Web integration to Google sheets
Troy,
I'm not able to answer your question and I'm sure Terry - g4pop will add some advice when he can.
In the meantime ... pls note I've changed your username login from "Troy" to "g7lhk" as that is what is requested for all users of the Log4OM Forum. See below:
See this message from Terry ... this is one of many posted throughout the Forum.
viewtopic.php?t=6249
Thanks Nolan,
I was trying to change my name to the callsign but couldn't figure it out!
Many thanks for doing that for me !!
Best 73 de G7LHK
Best 73 de G7LHK
Hi Nolan,
Just noticed - everyone elses callsign is in capitals - I've tried to edit mine but don't know how!
Any chance you could pop me in capital letters rather than lower case (being picky lol!)
Cheers
Cheers
It can be added at some point using the API that Google sheets provide
Where would you want it populated from the Log4OM Net control or the normal QSO input UI?
Ideally from the QSO Input, but I'm not sure at this point that all 3 of us use LOG4OMI. We
could do it using the Net control I guess, but I'm unsure how to do it.
Does Google sheets require a script to pull the data in, or can LOG4OM push the data through in real time - that's the issue.
Google sheets allows us all to see in real time the callsigns that have been added, - I'm not sure!
Appreciate the advice!
Best regards,
Troy G7LHK
Best regards,
Troy G7LHK
Anyone have any ideas on how I can achieve this folks?
Best regards
Troy G7LHK
Best regards
Troy G7LHK
Troy,G7LHK wrote: 06 Feb 2025, 00:45 Anyone have any ideas on how I can achieve this folks?
Best regards
Troy G7LHK
I already stated that integration could be added and even asked from where you would want it to be activated!
When we have time we will add the feature to Log4OM, but at this time there is no connection available!
Mu apologies - I obviously mis-read your reply,
However, I don't think that the response I got from you with the exclamation marks warreted that sort of comment, so I will remove myself from the forum.
