TCP QSO DATA TRANSFER : SOCKET OPERATION TIMED OUT
VE1XOP
Post by VE1XOP »
Just started today. Using JTDX and this error appears. The log still registers, but which socket is the issue with Log4OM?
Any suggestions for the root of the cause?
Re: TCP QSO DATA TRANSFER : SOCKET OPERATION TIMED OUT
I think this has been covered several times, it seems there is a setting in the JT software that you can change the time out interval.
VE1XOP
Post by VE1XOP »
Thank you - Problem was solved. Disabled a TCP setting.
txs
Sean
