Can anyone tell me if it is possible to Log from Log4OM to Logger 32 at the same time?
The set up is SUNSDR2DX, Expert SDR3, SDC and Logger 32.
Whilst using WSJT-X or JTDX, all works OK, QSO's are logged to both loggers fine.
What I want is SSB, RTTY or CW QSO's to be logged to Logger32.
Thanks in advance
Ian G4GIR
LOG4OM2 logging to Logger 32
Re: LOG4OM2 logging to Logger 32
Hi Ian,
If I am not mistaken UDP outbound, Page 192 + 192 in the manual, should do the trick.
Create the Port that logger32 listens to, give it a name, Service type Adif, save it and it should work.
73 de KF5WGB
Ralf
73 de KF5WGB
Ralf
Hello Ralf
Thanks for your reply.
Sorry for not replying earlier, I have had some issues here!
However, yes I saw that option but it still won't work with Service type ADIF.
I have tried other Loggers i.e Swisslog and LogHX, both of which work fine. The difference is that they have a service of "N1MM XML Format" Which Log4OM 2 dosen't have.
To get the QSO's from the other Loggers into Logger32 I am using a "N1MM to Logger32 Bridge" utility.
So unless I am missing something, I am wondering if it would be possible to add this service into the UDP outbound service selection?
Thanks again.
Ian G4GIR
Thanks again.
Ian G4GIR
