That worked, sending the Sh/mydx command, but when I shut down Log4OM and reopen it, the cluster has reverted to all spots. I did find the dialog to modify the login script (the little button next to the checkbox for 'run logon script"), so I've included it in there. Now it displays only the spots I am interested in every time Log4OM starts up! Thanks!
Doug
No longer "connecting" to cluster
Re: No longer "connecting" to cluster
Doug,
What happens is that your filters are not applies in the initial cluster load because this happens at the same time as login to the cluster.
If you wait after the initial,load all new spots conform to your filter commands.
Clearly including sh/mydx in the login script obviates this
I had an identical problem. I even tried updating the program to the latest version which still didn't help.
I should have come to this Support Forum first before wasting 2 evenings trying to fix it. I connected to GB7MBC as recommended and it's working perfectly.
Thank you.
Rob in Cape Town
Thank you.
Rob in Cape Town
Yes, sometime cluster nodes goes offline without notice...
i've set a list of clusters but i wonder if exists somewhere an updated list of active cluster nodes to be used...
Anyone knows where we can find a list?
