Yesterday my cluster stopped working.
Tried changing to half dozen or more cluster sites and get ....." cluster not responding msg" each time . .....and after not responding msg at top, a box opens with
" NOT CONNECTED "
The super cluster still works.
Im running version 1.15 of LOG4OM.
Tried rebooting several times.....?
Ive been using LOG4OM for 6 months or more....
A few weeks ago I had to change cluster from the default , because the site stopped working....
Ideas?
Thanks KD8CJ
Cluster not connecting, Windows8.1
Re: Cluster not connecting, Windows8.1
First, you should download and install the latest version 1.18.1
Can you check for errors in the software log?
Update:
All clusters that I tried did not work, about 8 or 9 that I got off the web. So I ASS-U-ME d that LOG4OM was broke.
Finally read another post on here with similar problem.
thanks to DF5WW mention of his cluster that he said was working "sm6.se:8000" ....I tried that one and all is working now.......
How does one find or know which clusters are good, looks like some are only part timers???
thanks to all
KD8CJ Wayne
thanks to all
KD8CJ Wayne
It's a hit and miss thing. The best bet is if you can't connect to one, try another. There is no unique reason why they go down for a bit.
VE7CC seems to be one of the most reliable.
