Hi.
Just re-booted PC and opened Virtual Machine ( as i use a mac ) and for some reason i cannot get the cluster to connect.
I have not changed any settings as far as i know.
Phil G7BZD
Cluster not connecting
Re: Cluster not connecting
Hi Phil,
try another cluster .... It´s possible that the cluster that you use is not reachable a.t.m. ......
Not a L4O problem ... here my cluster is working fine .... If you go to the "Utilities/Cluster" menu you find a drop down where you can change to another cluster .... You can also define a setting for your preferred cluster (i use sm6.se:8000) ....
Hope that will be help
what version of Log4OM are you currently running?
Hi Chuck,
think that makes no difference .... Used all former and the actual (1.18.1 release) of L4O but the cluster works always fine. Sometimes have had a problem with the cluster which was setted after install (when the cluster was offline) but a change to another one has resolved this problem ....
UUps ... i using Win7 64 bit and i see that the thread opener is using a VM with Windows at an Apple PC ...
yes, thats it, seems the normal cluster i was using is not working, got others in the drop down list.
Mac user running OSX ver 10.9.4, Virtual machine running windows vista and Log4om 1.18.1.0
Bit like HRD when the cluster fails, i just go for the next one.
Ohhh these grey moments, think i need a re-boot.
Phil G7BZD
Phil G7BZD
Hi Phil,
sometimes my "internal" PC also needs a reboot
Nice that we can help you
I think we all have, what I call "head scratchers" and that's why I'm going bald!
