I've searched the archives but drawn a blank, I'm looking for information on how to limit my log to show only the past month's contacts on a single band, the procedure i've been trying is QSO Archive, setting the date range, say from the 1st of April ---> 1st of May, setting the band filter for the band of my choice, eg 20m....then clicking enable update, yet when the result comes up it's showing a variety of bands dating bate over a year, what I'm i doing wrong?.....or is there a better way for showing how many DXCC's I've worked in the past month on a selected band.
Thanks in advance,
Gerry/Ei9Ju
QSO Archive
Re: QSO Archive
Queries should be made using the ADIF format of informations.
After setting the SEARCH PARAMETERS be sure to launch a SEARCH by pressing the search button again!!!
The parameters to use are:
QsoDate >= 20130401 (01/04/2013)
QsoDateOff <=20130430 (30/04/2013)
Band = 20m
Band = 20m
Re: QSO Archive
OK thanks, I'll give it another go.
Re: QSO Archive
I've followed the instructions. The search parameter field was been out as you suggested, "QSO date" "QSO end date" and the Band (20m), I then closed Search Parameters by clicking the green correct tab at the bottom, then clicked the "search" tab and nothing happens!
Re: QSO Archive
ei9ju wrote:I've followed the instructions. The search parameter field was been out as you suggested, "QSO date" "QSO end date" and the Band (20m), I then closed Search Parameters by clicking the green correct tab at the bottom, then clicked the "search" tab and nothing happens!
OK I used different dates because there were no QSO's in my log for the month you stated so I did it for February but it works for me..
- filter.JPG (117.13 KiB) Viewed 10742 times
Re: QSO Archive
Terry, I'm i exiting Search parameters as i should by selecting the green correct tab, then use the "search" tab top lefthand corner of the Archive box beside callsign or ios there any other "search" tab i should be selecting.
- log4om arckive.png (85.85 KiB) Viewed 10737 times
Re: QSO Archive
Please compare the search parameter (The >= signs) between the ADIF fields (EG QSO Date) and the value (EG 20130401) in your image and my one.
You are using equals (=) for them all
You need to read the instructions again and use the correct parameters which you select from the drop down list between the field name and the value boxes at the top of the search parameter window.
>= this means greater than or equal to
<= this means less than or equal to
= this means equal to
Re: QSO Archive
Thanks for the clarification Terry and once i sorted the >+ from the <= and included the = it worked.....but if you don't mind me saying, all that rigmarole just to select a time period
Re: QSO Archive
Gerry,ei9ju wrote:I've searched the archives but drawn a blank, I'm looking for information on how to limit my log to show only the past month's contacts on a single band, the procedure i've been trying is QSO Archive, setting the date range, say from the 1st of April ---> 1st of May, setting the band filter for the band of my choice, eg 20m....then clicking enable update, yet when the result comes up it's showing a variety of bands dating bate over a year, what I'm i doing wrong?
There is an easy way if you don't want to use the search parameters which is to do all of what you did above but click 'SEARCH' not 'Enable update'
You only click 'Enable update' if you need to edit/change any data!
I have just checked this is working fine as shown below so the procedure for the simple method is as follows
1. Check the date range check box
2. Set the start and finish dates
3. Select the mode from the mode drop down
4. Click the large 'Search' button at the top left hand side of the window - next to the call sign field
If you then need to reveiw your 40 meter contacts change the band in the drop down and click 'SEARCH' again
- Untitled.jpg (271.22 KiB) Viewed 10722 times
Re: QSO Archive
Now we're talking Terry as that's more the type of simple procedure I was expecting
, my mistake was in thinking the "Search" function beside the Callsign tab was for looking up a specific callsign and wasn't associated with bulk look-ups.
Thanks for your patience.
Gerry/Ei9Ju
Gerry/Ei9Ju
