New version External Logs do not update
iz0rga
Post by iz0rga »
Ver 1.19.0.0
I report after update:
- log on qrz.com is no more updated
- log on eqsl.cc is no more updated even if the field is marked as sent (EQSL Send status = Y)
- qso list on lotw is not updated even if upload procedure ends correctly (maybe there is just an ARRL server delay ?? )
pse hlp,
tnx in advance & 73
73 de izørga op Manuel
Re: New version External Logs do not update
Not tested all of your reported upload issues but LotW Server has problems and is offline since a few days .... They are working about the problem .... ;) ;)
iz0rga wrote:Ver 1.19.0.0
pse hlp,
tnx in advance & 73
I have just checked all of the external log updates and all are working fine from both of my computers.
Have you checked your settings in the Log4om options/external logs tab are correct?
Have installed 1.19 release now and checked again ....
qrz.com upload not works here tooo
all other uploads exept LotW (site down) working fine here
for qrz.com API Key is in the settings and automatic upload is checked but also don´t works if try to load up by mouse rightclick in the Recent QSO List
Have checked the Logfile and found this message: 2014-10-22 15:07:59.2362 INFO: QrzComUpload: STATUS=AUTH&REASON=user is unauthorized :!: :?: :!:
Crosschecked API Key at qrz site and in the settinge of L4O --- All is the same :?
iz0rga
Post by iz0rga »
Hi Terry, thanks for the quick reply.
Settings are ok, API key of QRZ.com is correct (call sign resolution works either while entering a new QSO or y clicking the update) and username, password, QTH nick of EQSL.cc are correct.
Everything seems ok on HRDLOG.net = everything works well :)
Thank in advance for your collaboration,
73 de Manuel
Hi, that "unauthorized status" come directly from QRZ.COM website. I've no ways to fix that.
Small suggestion: try changing your QRZ.COM password if contains strange chars like % and &
Don´t have special chars in my password but log upload to qrz normally don´t need any password. It only needs the API Key ..... qrz lookups are not activated here so i am not an XML subscriber ... Uploads has been working up to 1.19 RC 1 perfect. Maybe there are some changes at qrz.com in the last few days ??
Last automatic logged QSO was from Oct. 18, 2014 ... The imported ADIF log of WAG contest i´ve uploaded manually and the first automatic upload that not work´s was from 15:07 local time today with a brandnew installed 1.19 Release ....
Maybe a question for the owners of qrz.com :?: :?:
iz0rga
Post by iz0rga »
Me too, I don't have any special char in the pasword.
On qrz.com everithing was working well until yesterday night (Log4om 1.18) and stopped working after upgrade to 1.19. Maybe df5ww is right and they changed something in the last hours?
On eqsl the import goes but the record seem to be hidden, I am not able to see it in the log but if I do a Callsign query it comes :shock: (may be they also changed something?)
Each action is fully reported in log. Can you check traces of that activity in the log and errors?
Hi Lele,
eQSL no error messages in the log and QSO is already uploaded to eQSL. We can find the QSO on eQSL in the list of the actual month and also when we do an callsign query .... All is o.k. so far but in the complete downloadable ADIF or Textfile no QSO after 19.Oct.2014 is visible .... That must be a problem at the eQSL site .... :cry:
At qrz.com i got the "unauthorized" message and it looks like a qrz.com problem. Have asked about this error message in the qrz.com help forum but no answere yet :(
