Replace some information
ea1ciu
Post by ea1ciu »
Hello:
I need help to replace in the field QSOaward in a some of them a text .How make it?
Many thanks!
Re: Replace some information
Why and what do you need the enter?
ea1ciu
Post by ea1ciu »
I created a award with the name "Spain_Municipios_DME". Then, I make QSO and asign these qso to award and in the database is write "spain_municipios_DME@26056". Well, i need change this text for "DME" only to asociate these qso to DME award and not for Spain_Municipios_DME" beacause i change the name to award créate after.
Many thanks.
ea1ciu wrote:I created a award with the name "Spain_Municipios_DME". Then, I make QSO and asign these qso to award and in the database is write "spain_municipios_DME@26056". Well, i need change this text for "DME" only to asociate these qso to DME award and not for Spain_Municipios_DME" beacause i change the name to award créate after.
Many thanks.
Use the QSO Archive manager
sort/select the QSO's to be changed
Field update the QSO Awards field
ea1ciu
Post by ea1ciu »
No beacause replace all not parcial text.
How many QSO's require modifying?
ea1ciu
Post by ea1ciu »
I want to know how to do it . Right now I want to change about 300 QSO , however in the future , I want to know how to change the text in this part or other fields . It is culture.
Thank you very much .
OK with that many to change we need Lele to provide a custom query string for the QSO archive manager.
First of all, export your award in XML from award manager, fix the name with text replacement, delete original award and import the xml back.
Field name in db is "QsoAwards"
The fast way to fix your log, once you have set the award correctly, is to export log to ADIF, replacing "spain_municipios_DME@" with "DME@" and import back log into Log4OM
