Manual reading
G4DWV
Manual reading
Post by G4DWV »
Just reading through the manual about contests and on page 49 it discusses the contest (F4) tab.
It says, "The parameter ‘SENT’ can be changed...". By putting quotes around the word sent, it infers that one should see that word in the F4 tab screen shot. On checking, it looks like the screenshot could be from an earlier version as there are 'sent' and 'received' boxes under the 'enable contest mode' line in v 1.20.0.0
Cheers
Guy
Re: Manual reading
I will change it to make more understandable
Re: Manual reading
Done and will be included in the next release
contest.tiff
contest.tiff (295.74 KiB) Viewed 2572 times
G4DWV
Re: Manual reading
Post by G4DWV »
Thanks Terry.
PS Your graphic is not downloadable/viewable. The attached is all I get when I try to view it. Tested on a couple of browsers
