SMall issue with QSL manager
yt9tp
Post by yt9tp »
Whn I use QSL manager to update info for received paper QSLs I get into this issue:
My update routine is to set received QSL data and mark SQL snet status to requested if that is situation.
When I find QSO and click save button for QSL sent, upate is ok, but current record gets deselected. I have to select it again to be able to apply QSL received info.
Possible solutions could be to simply preserve selected records so it is not lost, or to provide option to apply both send and received info on one button click.
yt9tp
Re: SMall issue with QSL manager
Post by yt9tp »
Another issue:
When I use search filter to list QSO with Send QSL requested status, I cannot use options to apply sent status to selected QSO.
At the moment I try to switch to update mode, it resets selected QSO list, and reloads all QSOs.
yt9tp wrote:Whn I use QSL manager to update info for received paper QSLs I get into this issue:
Added a checkbox on screen to disable refresh while saving.
Will be available in 1.21
