Awards Manager File list is empty
LA9FFA
Re: Awards Manager File list is empty
Post by LA9FFA »
Did you get the logfile Terry ?
Yes but need to speak to Lele, so will respond hopefully tomorrow
LA9FFA
Post by LA9FFA »
Sounds great Terry , Thank you.
Log reports issues on reading activation database.
Please zip and send me a copy of your database, while replacing your one in roaming folder with a clean one ATTACHED HERE (need to redownload all awards from update menu)
activations.zip
Activations clean database
(966 Bytes) Downloaded 257 times
LA9FFA
Post by LA9FFA »
Well the activations.SQLite in my roaming dir is 0 kb in size :-) After replacing the downloaded file and updated the awards all is now ok.
dk2lo
Post by dk2lo »
This fix also worked for me. Thank you very much! Any idea how this can happen?
73 Olaf DK2LO
to be honest... no...
a couple of logfiles from the period when the issue happened could greatly help me
lele
dk2lo
Post by dk2lo »
Hi Daniele,
when this happened I tried to send my log file on 24th of January via the private mail option in this forum to you. This did not seem to work because i never got an answer. Later I was offline for some time. I do not remember where the log is stored. Because the issue is solved now I suggest to trace it if it happens again.
Thank you very much for your help and the best logbook of the world!
73 Olaf DK2LO
