Greetings!
I am trying to help out a friend get Log4OM up and running. We are trying to get the Log4OM keyer function to talk to his Rigblaster Advantage with no success. I may not be possible, as I find no reference to WinKeyer compatibility in the Rigblaster documentation. But the Rigblaster will handle CW keying with a com port assignment. But assigning its com port within the Log4OM results in an access error. I just wonder if anyone else has succeeded with the Rigblaster Advantage?
Thanks!
Doug - W7DRM
Log4OM keyer work with Rigblaster Advantage?
Re: Log4OM keyer work with Rigblaster Advantage?
Rigblaster advantage does not have a built in Winkeyer it's just a CAT and audio interface
You friend will need to purchase a separate Winkeyer
Try MRP40 for CW with the advantage if your friend does not want to buy a Winkeyer
