Page 2 of 2
Re: Clublog update
Posted: 23 Aug 2014, 16:23
by HB9ETR
yes, sure..
I get a "Y" in the update column and if I go to Clublog I can find the QSO.
On manual, I get a "N" and cant find the QSO on Clublog.
Re: Clublog update
Posted: 23 Aug 2014, 16:54
by HB9ETR
I downloaded and repaired my install and now all is ok.
tnxs for inputs
Re: Clublog update
Posted: 23 Aug 2014, 17:05
by DF5WW
Thank´s for the informaton
Re: Clublog update
Posted: 25 Aug 2014, 16:10
The error reported is a timeout:
Code: Select all
2014-08-23 10:27:06.6239 ERROR: *** ClubLogManagement: Upload to ClubLog caught in error ******* [Function: sendLogThread_DoWork] System.Net.WebException: [color=#FF0000]The operation has timed out[/color]at LogOM.BL.ClubLogManagement.DoSend(QSO qso, String url, String email, String callsign, String password, String apiKey)
at LogOM.BL.ClubLogManagement.sendLogThread_DoWork(Object sender, DoWorkEventArgs e)
2014-08-23 10:27:06.6289 ERROR: *** ClubLogManagement: upload caught in error with code:
It seems the answer from clublog requires an higher timeout or website was busy...
Re: Clublog update
Posted: 25 Aug 2014, 18:03
by NN7D
One thing I have noticed with Clublog is their update to where you can see an addition to your log on Clublog.com is very slow. I can do the right click on a log entry and add it to Clublog, with no errors, then go to Clublog and the qso is not displayed for some time. I can re-add the same qso, and the Help/Show Log report will show a dupe, but still no update in the displayed Clublog log. If I come back in several hours, the updates are displayed. So they must have a back-end which is updated immediately, but their front end which displays the log online, is slow to get the updates, which makes it challenging to troubleshoot.
Doug
W7DRM
Re: Clublog update
Posted: 25 Aug 2014, 19:10
by K7PT
It's like what happens on LOTW, takes a while in the Q before you see it in your Recent QSOs.
